Still looking for a reply to #119, above.
				Results 121 to 150 of 221
	When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
	My preview window used to work just fine now it won't work anymore. I get this error message anyone know how to fix it "preview window will not be displayed under current pc"
	I've no idea to tell the truth. These devices do not capture to a PC, instead they capture to a USB hard drive or Flash Drive then you can move them to a PC. They also seem to state they're mainly used with set top boxes/cable boxes, where as most of AVerMedia's devices are for capturing games (or anything with an HDMI outout really). The name "EzRecorder" just makes me think they're possibly just general use capture devices. I'm just speculating though, so don't take my words too seriously.
 I'm guessing that means you have "Current PC" set as the main capture profile. It assumes you're capturing from the PC you're currently on and therefore no preview window will be/needs to be displayed.
 See if that's the case, and if so select Advanced, then select Game Console under Platform (or Other PC). The preview window should then appear.
 If not, then... no idea. But the fact the error message states Current PC suggests that to be the case. The preview window NEVER shows up under Current PC either, because it's not needed. It just captures the entire Windows desktop and any full-screen applications.Last edited by PureChaosX; 28th Mar 2017 at 07:38.
 If not, then... no idea. But the fact the error message states Current PC suggests that to be the case. The preview window NEVER shows up under Current PC either, because it's not needed. It just captures the entire Windows desktop and any full-screen applications.[/QUOTE]
 Thanks for the help. What exactly is the difference between Current PC and Other PC? I looked at it and besides system sounds i didn't see any difference.
	The differences that I can see is that Current PC is when you are capturing on the same PC you're playing the game on, or whatever it is your capturing.
 Other PC is similar to Game Console, in that you play the game on one PC but capture on another. The only difference is the Audio In option, which I guess is only relevant when you use the PC audio output jack. Hope that helps you out!
	I was hoping I could record some Tv programs via ExtremeCap U3 once there is released a software for surpassing HDCP protection but I couldn`t do it.
 Maybe I could not set things right? I have a 4k tv Philips 42PUS7809 with 4 HDMI but nowhere in the user manuals says this connection is also a VIDEO and AUDIO OUT in order to send the signal to ExtremeCap U3 ...
 Could someone help me with this one? Much appreciate that ...
	TVs do not have any video outputs on them (only audio out via optical or 3.5mm jack) but all video ports, such as HDMI, composite, component etc are inputs only.
 In order to capture TV programs you'd have to connect a cable/satellite TV receiver to the Extreme Cap U3 via the HDMI as only those kind of devices have outputs.
	Thanks for this, I already had a working splitter, but this allows me to have one less component and a couple less hdmis in the rats nest.
 The latest 109 exe even seems to be working fine for the update recently released 112.
 I even have an hdmi switch in the mix so I can choose which hdmi source I want.
	I seem to be having a problem all of a sudden with RECentral. I've just replaced my LGP (used with a laptop) with a Live Gamer HD (for my PC) and installed the same version of RECentral (v112) on my PC that was on the laptop. However, it seems as though RECentral on the PC "silently" crashes whenever I stop recording.
 I have to force close RECentral, meaning whatever was recording is gone, with the file only taking up 1Kb, even though the separate MP3 track is fine. Also noticed that if RECentral doesn't crash, it's actually CLOSED ITSELF. This only seems to occur when capturing Current PC with full screen games. Capturing an external device, such as an Xbox One, appears fine. Any thoughts?Last edited by PureChaosX; 19th Apr 2017 at 19:13.
	On GL310 i get a picture from my PS3, for a few seconds. Than it goes to no signal (without the patch the picture keeps working, but I cannot record due to HDCP).
 About 20 seconds later I get my PS3 signal again for a few seconds, than again no signal, and so on...
 So technically I could work, but not stable. Reset the PS3 with the IO button while connected through the Avermedia GL310.
 reinstalled, tried different versions (mostly using 1.3.0.104)
 Any tips?
 Thank you
	Hi guys,
 some news about Avermedia C985 card:
 New Firmware released - Version 24 (Fixed bug to support " Nintendo Switch game machine"): LiveGameHDUpdate_17050209.zip
 New software version: C985_RECentral_1.3.0.115.2017041901_Drv_3.3.x.52.e xe
 Claudio
	Cauptain...
 Dude...
 I can not tell you how great a favor you make me...
 I do not go into English forums because I do not know. But I signed up here to thank you.
 I did not know what to do with the HDCP error.
 Thank you dude.
	thanks that! extremecap u3 it's working,  i hope RECentral 4 will update in here too? i hope RECentral 4 will update in here too?
	This no longer works for the Avermedia LiveGamerPortable/C875 as of 01/12/2017.
 Is this project still being worked on? Or is it, like so many other video game hardware related hacks, simply being ignored until it goes away?
	RECentral4 has been release! is there anyone can make a mod/patch exists for RECentral4?
	Hi all,
 Sorry for the delay in answering. A lot of work at the end of the year.
 Unfortunately no further update will be released as AVERMEDIA has stopped updating the REC. (2017-06-15 - Last update)
 For make work just use last version on site.
 Version 4 is only for the newer products (Supports: LGP2 Plus (GC513), LGP2 (GC510), Extreme Cap UVC (BU110), Live Gamer Extreme (GC550)
 Happy New Year to all !!
 Claudio
	Cauptain
 i have a question, same way to remove amarectv's hdcp? like recentral this application can compatible avermedia many device
 https://mega.nz/#!g90Byb7S!r3KdXPhNMk2vcSgaGTr17TPbkaeHKQZ5gmpVXqsL1uQ
	Nope. In the past was an application that allowed to do this, because the drivers are hacked. Currently the application(RECentral) is hacked, driver hacked it does not work anymore.
 I stopped use AmarecTV in version 3.10C. The version 4 is very poor compatible, non english language and very very buggy.
 Happy New Year, guys!!
 Claudio
	OP Thank you!!!
 It works great with my Extremecap U3
 For people looking for a HDCP ripping splitter I can confirm this one works on ports 3 and 4 http://www.ebay.nl/itm/4-WAY-HD-hub-1080p-1-x-4-HDMI-3D-Splitter-Amplifier-Switcher-Hu...r/290724340294
	Cauptain, TriRozhka & StNt, thank you very much!
 The patch works like a charm!
	So what driver do I use for the HD GL310? I tired each one and each time I open REcentral it tells me "No device detected."
	I searched through the thread for this but might have missed it so apologies for the repeat question if this has been answered before.
 I had set my Avermedia EZREcorder 130 to capture 720p with the lowest bitrate and was getting 6GB files for about 2 hours of recording. At some point I unhooked the hdd to dump some files since I basically use the Avermeida as a DVR. When I hooked it back up my files bloated; it was now recording 1080p. I recently swapped out the HDD and saw the 1080p option when Avermedia was doing its HDD check. I was thinking that would be best since I am recording a mix of 1080p and 720p programming, but now regret that choice since the files are large. Given that preamble:
 A. Is there a way to set 1080p or 720p for a specific recording? If I am recording a 1080p channel then I could use that option and a 720p channel could then be set at 720p?
 B. If it is not possible to do what I asked about in (A), is there a way to change my settings with the current HDD so that I am always recording 720p?
 Thanks in advance for the help.
	the new version rec4 has been release! no one can remove hdcp from this?
 REC4:http://ftp2.avermedia.com/RECentral%204/RECentral_4_v4.1.0.18_180416_x64.exe
 ITS FOR GC550:http://ftp2.avermedia.com/GC550/GC550_RECentral_4_v4.1.0.18_180416_x64_Drv_3.0.x.99.exe
  AverMediaBy mapkel in forum Capturing and VCRReplies: 0Last Post: 15th Feb 2015, 18:43
  Yes I am recording HDMI HDCP over Avermedia LGP Lite Capture- simpleBy BobbyGee in forum Capturing and VCRReplies: 8Last Post: 19th Sep 2014, 07:54
  mpg2 avermediaBy JAX75 in forum Video ConversionReplies: 2Last Post: 28th Jul 2013, 14:00
  Problem with AvermediaBy JustRyuzaka in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2013, 09:34
  Confused with AVerMediaBy v19 in forum Newbie / General discussionsReplies: 13Last Post: 21st Jan 2013, 16:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
 w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
 though not yet assigned to that task]
Shuttle SH67H3 (i7)
 w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
 services for an office, with other computers
 there . . . ]
Various older model Lenovo laptops, like T-40
  series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
 & various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
